8715705019012
Výrobca: Top Racing
Kód: 19963
€167,80 s DPH
High Quality Racing full circle crankshaft from Top Racing. The specialist Portuguese crankshaft manufacturer is a symbol of high quality crankshafts. Increased pre-compression in the cases for more efficient filling rate. Power band shifts to a higher rev range. Due to the increased inertia of the solid metalDesign, performance and torque are improved. It should, however, be used with 70cc cylinders. In 50cc cylinders, the performance increase is somewhat lower. The crankshaft is supplied with small end bearing. Made in Europe
Výrobca skútra PGO
Model skútra Big Max 50 AC, T-Rex 50 AC, Hot 50 AC, PMX 50 AC, Tornado 50 AC, G-Max 50 AC
kľukový hriadeľ Top Racing zosilnený high quality pre PGO nový motor
€167,80 s DPH
